Fly Easy: Air NZ CPAP Machine 101 | Club Discussion
Traveling with a CPAP (Continuous Positive Airway Pressure) machine can seem daunting, especially if it's your first time. However, with a bit of preparation and knowledge about the guidelines, flying with Air New Zealand can be a breeze. The CPAP care guidelines as specified by Air New Zealand are outlined below, along with some essential travel advice.
Preparing for Your Flight
Consult with Your Healthcare Provider
  • Before you plan your trip, ensure that you consult with your healthcare provider about your travel plans.
  • Ensure you have a travel-friendly CPAP model if possible, as some may be more compact and lightweight than others.
Contact Air New Zealand in Advance
  • Notify Air New Zealand about your requirement to use a CPAP machine on board. They may have specific procedures or documentation you need to complete prior to your flight.
  • Check if your CPAP machine is considered a carry-on or if it requires a separate check-in. It usually does not count towards your carry-on baggage allowance.
Pack Appropriately
  • Pack all necessary components of your CPAP machine, including the mask, tubing, power cord, and any adapters for different power outlets.
  • Always carry your CPAP machine in a sturdy, padded bag to protect it from damage.
  • Consider getting a letter from your doctor stating the necessity of your CPAP machine for your health.
At the Airport and Security
Security Screening
  • Be ready to remove your CPAP machine from its bag for X-ray screening.
  • If you have distilled water for a humidifier, check the airport’s and Air New Zealand’s liquid policies.
    Boarding and In-Flight Usage
  • Arrive at the gate early and inform the staff that you will be using a CPAP machine during the flight.
  • If your CPAP needs power, ensure a battery pack is available or request a seat with power access (not all airplanes offer onboard power supplies).
On Board the Aircraft
Setting Up Your CPAP
  • Set up your CPAP only when ready to sleep to maximize its usage within battery life or power availability.
  • Use a sanitizing wipe to clean the area around you before you set up your machine.
  • Avoid using the water from the aircraft in your CPAP’s humidifier; instead, use only distilled water.
During the Flight
  • Try to maintain a normal sleep schedule, as it's best to use the CPAP machine while you're sleeping.
  • If you’re experiencing discomfort, don’t hesitate to ask the cabin crew for help.
CPAP Care Guidelines
Maintaining Your CPAP on the Go
  • Always empty the water from your humidifier before moving your CPAP machine to avoid spills and damage.
  • Clean and dry your mask and tubing daily to prevent bacteria build-up.
  • Check voltage requirements for your CPAP machine. Some countries may have a different voltage than what your machine is configured for.
Hygiene and Privacy
  • Use a privacy screen or blanket if you’re worried about your privacy while using the CPAP machine.
  • Keep your CPAP clean with sanitized wipes specifically designed for electronic medical devices.
After Your Flight
Post-flight Care
  • Fully clean and dry your CPAP machine after your flight to ensure it’s ready for the next use.
  • Recharge any battery packs you may have used during the flight.
Flying with a CPAP machine on Air New Zealand is straightforward, provided you plan ahead and follow the airline's guidelines. Remember, your health and comfort are paramount, and with these tips, you’ll be well on your way to easy flying with your CPAP machine. Safe travels and sweet dreams at cruising altitude!
Location Info
Address: 17360, 2832, New South Wales, Walgett Shire Council, Walgett, AU
Latitude: -29.6731407 ; 148.2482286
Sitemap
Contact Us
